Vent Problem
Cadaver
2003 Mazda 6s
Has anyone had a problem with switching the vent from the Window (defrost vent) to the passenger vents? Everything else works fine but I have a hell of a time going from the window to passenger. Just want to know if I'm the only one with this little annoyance.
Thanks
Yes, I have that problem. Seems the ACC has a mind of its own when setting the temperature and where the vented air is supposed to go. I figure 72 degrees should always be air conditioned air, but when it gets cold outside it switches it to heat. I don't need the heater!
