Unlocking and Locking Success
zul114
Well I have wired everything together for unlocking my car through my e-brake. I would like to unlock my car when the e-brake is up (that is DONE) but I want to lock my car when my e-brake is down. For some reason I can't send a pulse to the lock module.
I am using a pulse timer and relay
I have attached a drawing of my wiring. Could you guys take a look at it and tell me what I should do.
Thanks so much
OK, from looking at the diagram you should be able to remove the relay from your current circuit, it's just acting as an amperage amplifier adn I don't think you need that for the timer relay. Unfortunaately it's been about 2-3 years since I've used a pulse timer and I don't completely remember all the wiring and circuits on it. You should be able to use one to do both lock and un-lock but you might need two to do it. If you could post or send me the instructions sheet I can look it over and make sure.
AWESOME!!!(headbang)
I want to know more.
Can you give me more detailed instructions on how to do this.
I will scan in the diagram for the pulse timer, I have a feeling I will have to run another relay into the pulse timer not sure yet.
Jason
Well i tried hooking up a resistor to the relay to make it lock, but I am getting no luck.
could something in the pulse timer keep it from dropping the voltage
Please help, I can't figure out how to lock the car through the pulse timer
Here is the wiring for the pulse timer. attached in the beginning is the wiring i have done so far.
Please help
Jason
