Undercarage missing screws!!
Kyrosfactor
Contributor
MazdaSpeed3
Does anyone know the demensions of the screws that hold the undercarrage up underneith the engine. Thinking 10mm welded washer bout 1/2 inch? Lost one of the three, flapping in the wind. Thanks!!
You can get them at places like Orchard Supply Hardware (in Calif.) or other good hardware stores if you need them. yes, they do have the embedded washer if you want an exact match. Otherwise, a separate screw and washer could be used.
Just a typical 10mm bolt with a washer would be all you need. We use them as replacements when cars come in without them. Dont need to go anywhere special other then your local hardware store. And theres a total of seven. Make sure the ones on the sides are still there, or you will be spending about $185 for a new splash shield, after you hear a rough scraping noise as your flying down the high way.
