two possible setups
elderlycoffee
2007 Sunlight Silver mazdaspeed 3
I'm trying to decide if i want to be stealership friendly or screw the warranty.
If i want to be able to be warranty friendly and have parts i can put back to stock quickly i'll keep my MS CAI get the MS exhaust and an ETS TMIC.
If I don't care I'll get the corksport FMIC, corksport exhaust.
which should i do
tmic equal gain dealer friendly stealthy....only reason for corksport is to give that mean front mount look
you could try talking to your service advisor about modding your car, and to see if mazdaspeed tech there would approve of you modding your car while making visits to the dealership, what's the worse that could happen? If they say no, then just come back to this thread for the end result lol
the corksport intercooler has a larger than stock MAF housing, plus you can't use your cold air intake with it. also, who cares? the corksport downpipe and midpipe are going to get you the best gains and they probably take less than an hour to swap out if you need to. I'd get the top mount intercooler, the downpipe and middpipe and call it a day.
TMIC can be removed in 20 minutes...so you can just yank it before it goes into the stealership and put the factory one back on.
The Mazdaspeed CAI shouldn't be any problem.
for dealer friendly...I would get TMIC, Mid Pipe and catback of choice (if you want better sound)
Takes you that long ? I think you can shave a couple of minutes off that time with practice. Try a bit of throttle lift pre apex and the rotation that occurs will allow a quicker settling allowing wot exit. wait what was the question dp?
i know the ms cai isn't a prob with the dealer i had them put it on but if i get the corksport fmic it replaces it with ram air.
which should i do
"My advice to you is to start drinking heavily, right now." fear and loathing in las vegas.
(nana)
