Also someone was talking about a upgraded TMIC . I dont understand what that would do . They look as if they are the same as the stock TMIC's ?
ETS makes an upgraded intercooler sold on the protegegarage.
This is from the ETS website:
3.25" flows 1176 CFM (705hp based on flow, inlet/oulet restrict flow to ~600hp, surface area = 450hp at ~50mph, speed required for this power rating due to flow through the scoop)
Meaning that this intercooler is capable of up to 450hp, primarily based on the size of the ducting and the inlet/outlet of the intercooler.
Seriously, 500 hp on this car is VERY VERY unlikely. I know you have good intentions, but, here is a quick summary:
Stock block is definetly not capable of 500 hp. There are some people with 300 whp, but they have been tuned by guys who know these cars inside and out, and for the most part, I would not trust a stock block with over 350 hp as a daily driver .. especially if you have a lead foot.
Protege garage has an upgraded forged engine with better rods, pistons, and a lower compression ratio. Only problem is that no one has been able to effectively use this new engine for high horsepower applications because tuners have not been able to figure out the tuning software.
Then there is the drive train: The clutch is crap in this car at any thing over stock torque. The rear differential cracks and breaks under aggressive driving in stock form. The driveshafts are about worthless, and I am pretty sure that the AWD electromagnetic clutch will have a limit shortly.
You say you have the cash .. well, It is my honest opinion that you are looking at well over 20,000 dollars for 500 hp, if that can even happen.
