Turbosmart BOV problem
ms6DiGi
Contributor
Mazdaspeed6
I just installed my Turbosmart dual port bov a few days ago and everything has been fine. Today I was driving a little harder than normal and my check engine light went off.
The car is still running fine and everything sounds okay. Anything I should check off the bat tomorrow morning?
BTW
I have it running 50/50.
BTW
First thing to do is pull the code and see what it is. Then you can figure out which direction to go from there.
yea i had the same problem i was running 50/50 and the car leaned out a bit so i altered it to run 100% recirc and its been fine ever since.
Samething. I was pulling CEL 301 in 50/50. Put it back to recirc and the code is gone. Couldnt be any happier.
heh, thats why i went with the BPV instead of the hybrid.
full recirc ftw, i knew id end up going 100% recirc with the hybrid for those very same reasons. and paid way less to boot! :D
