Turbo Timer for Speed 3
Doubtful there will a plug n play harness available anytime soon if at all (there never was one made for the MSP) So you would have to buy a TT (whichever you prefer) and wire it yourself.
i doubt a plug and play harness will be available for any of the units out there, but they are not hard to wire in on thier own
unnecessary modification on the MS3. The car (like a lot of modern TC cars) doesn't need time to cool the turbo, unlike older ones.
Thermal siphoning from the water cooled turbo thats in the MS3 will cool it down even after the engine is shut down. Water will flow gently until there is not enough heat in the turbo to cause the thermal siphoning.
In essence, your car does it for you. So does mine, I have an MS3 too.
Unless you are boosting for quite a while, then shut the car off immediately, like within a few seconds of being in high boost, the cooling will be fine without running a turbo timer.
My advice? Save the money for the new CAI coming out from MAZDASPEED here in a bit. thats what I'm doing.
Ummmmmmmmm...... Not sure about that one since it Sayes even in the manual to allow 30-60secs for time to cool down the turbo after a long or hard drive. And Im also pretty sure that they are oil cooled. Instead of buying a turbo timer just sit and listen to a little bit of a song before you turn it off! Unless your looking into boosting options aswell.
Todays Project: Make your own slaloms in the snow!!!! ENjoy
only 30 seconds.. you want to spend 100$ on that?
For knowing so much about turbos, why would you put a CAI on a turbo car. That is worthless. Just slap a SRI on it and be done.
And yes even in todays forced induction cars you still will benifit from a FATT. The manual states there is a needed wait time, and I doubt he is going to drive it like a grandma. They are a cheap and inexpensive way to prolong the life of your turbo and stop and possible damage.
Yes, you are correct. I used the incorrect term when I said CAI. I do agree, with a turbo there is no need to tune the intake length. The term CAI just came to mind when I think of better breathing. Not sure if its out yet, but the MAZDASPEED intake setup for the MS3 seems to do very well. Reviews said it may be good for 30HP and a bit better driveability.
With regard to the cooldown, yes the manual says that after hard boosting it is important to idle for 30-60 seconds. But, because this IS a water-cooled turbo (as opposed to solely being an oil-cooled one), unless you were running really, really hard just a few seconds ago, turning off your engine after, say, finding a parking space, should be more then enough time for the scroll to slow down, and the cooling to do fine on its own, after shutdown. I could certainly see you needing to run a turbo timer after pulling a "Fast and the Furious" parking job, or after shutting her down right after running up a mountain on boost. So, in that way, I agree, I'd wait before shutting down.
Also, I don't know if a lot of people know this, but most high-end alarms today have a turbo-timer feature built right in. Makes sense, since the alarm is wired into the car pretty heavily. So, one possible way to go is to buy a top of the line alarm, and then just set it to run the car for 30 seconds after you set the alarm.
The turbo in the MS3 is lubricated with oil, but cooled with water. I'm sure its cooled somewhat by the oil, but water is the primary.
I guess bottom line, if you want one, get it, because its your money as always. I just don't think this car needs it nearly as much as the old 300Zs, Supras, 240sx turbos, RX-7s, and all that. The oil coking issues in these cars is omnipresent, but the newer turbos like the MS3's enjoy the advantage of thermal siphoning, a natural effect of using water.
Hehe, he's right, my compustar starter/alarm has a turbo timer feature. I wish I needed it. =\
