Turbo system.. Starting form scratch..
curt2go
2003 P5
Ok I am new to all this. I come from a chevy racing bakground. I do have blower knowledge to work with . I was wondering how many of you have done a turbo system in your car from scratch. Is it worth it $$ wise ?? What all does it entail. Do you know of any good book to do some reserch with??? Sorry if this is a dumb thread but a little help for me will go a long way.. I have access to have all the piping made any way I want it. Thanx guys..
PS It will be going into a 2003 P5
Looks like a new version of it was released in april 2003....
Maximum Boost: Designing, Testing, and Installing Turbocharger Systems
by Corky Bell (Paperback - April 2003) I am ordering right now.. Thanx
i dont think adding turbo to a Pro of any mod is worth it.
you go fac turbo-145-165 in hp gains
you go max boost-depending on stage u get much better numbers, but at the exspense of your internals needing major work and emissions r dun
not to mention new drive shafts and clutch work.
best bet is to go for the NA build, fsze style. just my opinion but, iluv my P5, and i understand that whatever i do to it, thiers a world of other cars w/ the same mods that will eat me up.
Several kits, Flyin' Protege's included, are emissions legal in every way. The FP kit was engineered by Corky Bell, author of the aforementioned book in this thread. The Protege engine will handle on stock internals up to 12 psi of boost from a T3 intercooled setup with fuel control. This has been proven time and again through repeat tests by many people.
there is no evidence that new drive axles of any kind are needed for turbo applications. if you burn out all the time from every light, regardless of whether or not you are turboed, you will eventually need new axles. drive smart and you won't have this problem. I went more than six months with the stock clutch and even when I changed it, it was in perfect shape - i wanted a lighter flywheel and because the clutch was right there, figured what the hell :)
this is hardest, one of the most expensive and fruitless paths to modifying the engine you can take. high compression pistons will give you maybe 25 hp, cams on top of that 10 to 12 hp. The labor to have these parts installed plus parts cost will run you as much if not more than a turbo setup for less than half the power gains. Doing an FSZE engine swap is pretty useless unless you can swap the entire electrical system and ECU over to the Japanese spec OBD1 (USA runs OBD2). The ECUS are also NOT swappable on thier own. The 170hp FSZE engine plugged into an American ECU will yield you ZERO gains over an 130hp FSDE. Ask LinuxRacr, he's gone that route with little positive result.
another member of this forum, Chdesign, went the "all motor" NA route with his Protege and gained about 30 wheel horsepower, and his was the most complete, well done NA protege I've ever seen. My turbo kit at a "mere" 6 psi gains about 75 wheel horsepower. And there are stronger, faster kits being offered now.
Thats the way uh huh uh huh I like it .... Turbo's for sure are the best power increase. For me only being on the block for a short tiem can see they are very reliable and the hp returns are awsome.. TTY
Talking WHP the P5 has about 105 from the factory right. With adding about 6lbs of boost(TO START ONLY) what could be some WHP numbers to expect?? I know there can be a big variance but some ball park figues???? Thanx guys... TTY
Anywhere from 150-190whp
The most difficult part of building your own system is the manifold. We sell them for $450. I sell alot to guys that piece there own systems. The downpipe is another. Once you have those pieces all thats needed is the turbo, parts, I/C and make the piping at a muffler shop:)
Yeh I know. I'm sorry. I was just looking for the easy way out.. hehehe. Thanx for not :mad: flamming me... TTY
The pipeing definately won't be made at a muffler shop. :) It will be stainless tubing that will be tig welded and polished after. Are the flanges for the downpipe availible... Then I would be able to make my own..
Hey spoolinmp3 How much do you sell the manifold and downpipe for??? TTY
I really like your disign on the manifold. I love the tubular design fo better flow.. It will hold any turbo I would assume .TTY
PS. I have ordered the book and having it expidited to me so I won't have so many stupid questions. You guys can ask me stupid ?? about small block chevys if you like.. :) TTY
