igdrasil said:Oh yes, the axles, tranny, clutch are strong and will hold for 200whp just fine, I ran 200whp for 2 years, never broke anything except the rods, past 220whp. The block is strong, even stronger than any same class honda engine. Handling is a lot better than the same class hondas.
The engine breaks because of the lenght of the stroke, thats it. You put this same stock rod on a shorter stroke engine, and it will hold way much HP than on the FS engine.
Exactly, the stock setup will hold more then 200whp safely if done right! I ran for over 1 1/2 years making over 220whp and almost 3 years making over 200whp, so to say the rest won't hold up is BS. No we will not make the power that honda's make, but 200whp is a very reliable number if done right!
