Turbo Pics.....
Hey cool, wish could have shown up at HIN, I like your headlight conversion!
thank you sir....yeah im still working on it....got to clean up all pipes and stuff....
Nice job! Custom setup or what? And what's w/ the MF2? Any info on that?
well its a chdesign kit.......mf2...t it runs 2 extra injectors, gives them fuel when at boost so you dont run lean.....its really cool...you can really feel the difference....
i'm still faster (first)
you will probably read this before i talk to ya tomorrow morning ,but cesar is gonna hook it up with a heat shield :)
MF-2 is a Dual injector setup with a EIC to control the injectors. This system is widely used by F-MAX turbo kits. The system is okay, although I prefer the SDS EIC over the MF2.. but both should be adequate for mild boost/hp appliactions.
Hey man, your rides coming along nicely, im getting jealous. I wanted to know where you got your headlights from. Did you just swap them off a P5, and was it easy to do? Keep up the good work.
yeah had to just swapped them out froma p5...install is realle easy....sucks if you have to replace low beam bulb on passengers side.....washer fluid kinda covers it so its a b**** to reaplace....thanks all for comments.....need to get ic installed....
looks nice man. props. i was just wondering... how'd you do your gauges? (the chrome rings around them). they look nice, is that custom or is it a kit you can buy?
Nice set-up...always a fan of the FI! How's the blitz BOV (i think) working for you? I wondered if those were very stiff and sounded good or not...
Where did you get your guages from? Your dash is the bomb!!! Any websites that I can look at to get it myself...I give you mad props for the turbo baby!!!! NICE (2thumbs)
p5blk_stal (blackp5)
gauges....boost and airfuel.....summitracing.com...boost from a forum member...other gauges are stock....just have davebrings...they are awesome...
I really like the headlight conversion! It takes out some of the lines that break up an already nice front end.
On a side note; BOOSTED (thumb)
Looks good mon, much better that my first turbo pics. Take your time to clean it up. what kinda boost are you running?
right now i lowered it to 5...was running 6......but no ic...yeah finished cleaning all pipes and painted them "gunmetal"...they are nice....i polished them first then a few coats of spray and they look freaking awesome.....
oh...so YOU cleaned them, polished them, spray painted them? hmm, interesting...see, thats the reason why you are still (second)
