See my sig, i'm from south africa and have the european spec mazdaspeed (mps)
I want to install a tune, but this tune was developed at a high altitude, 2000m (6500 feet) above sea level. As i stay at the coast i want to know if this is safe and what to look out for. I already heard that a tune for high altitude may run leaner, and that some experienced worse performance at sea level with this even though the air has more pressure. What I dont know is if the tendency for knock is increased, or if the ECU automatically make the corrections. I am running 95 octane (unleaded ULP). I dont plan to run 98 octane as its too expensive and hard to find.
The pressure going from 6500 feet to 0 would relate to a difference of 4 psi of atmospheric pressure. As well as increased humidity ie water particles (vapor) in the air.
This tune is been tried and tested at the high altitudes but not at the coast, I want to know if it is safe.
