TSW Donington 19x8, will it fit?
zeruin
2015 Mazda CX-5 GT
So this is my first post here, but I'm buying a 2015 Mazda CX-5 GT on Wednesday and I'm looking for some info on aftermarket wheel fitment. I've read over a couple of posts, but I'd like to double check.
The wheels I'm looking at buying are TSW Donington 19x8 with 42mm offset. I believe the stock GT wheels are 19x7 50mm offset. Discount tire confirmed they will fit with only a 21mm extension out compared to the stock wheels. I want to reuse the stock tires and the rep said they are good up to a 8" wheel width.
Long story short, do you guys think will these wheels will still look ok? How much further did your aftermarket wheels stick out compared to the stock wheels? These are gonna be 21mm or so.
It will probably look silly, and pose a greater risk for wheel damage. You could always buy tires later if you don't like how it looks.
The wheels will fit and the tires may fit, but not correctly.
You'd be better served with 235 or larger tires on the 8" wide rims.
