2014 CX-5
The low beam on the driver's side is not functioning, despite all the other lights operating normally. I verified the bulb's connectivity and confirmed it was operational, then even replaced it with a new one. The fuse is intact, showing a voltage of approximately 11.5V on both sides. I even swapped the left side with the right side fuse. I also swapped the relay with the AC relay, AC works. There is no corrosion in the socket, and the wires appear to be in good condition. I did not measure any voltage at the socket when measuring to the chassis ground.
Could the issue be with the light switch module on the steering wheel? I would greatly appreciate any assistance.
