Trim Fastener - Oil Filter Service Cover
  • Thread starter Thread starter 172499
  • Start date Start date
1
172499
I just completed an oil change on my 2018 CX5 and noticed that I am missing one of the plastic trim fasteners on the small service cover to access the drain plug and oil filter. Does anyone know the size (8 mm x 20mm?) of the fastener or part number? I would like to order (e-bay) several extras.
Thanks,
Wade
Thanks,
Wade
Mine was missing one too. I noticed on the 2nd oil change, since the dealer did the first. Next time I was in I asked them for one, since I assumed they failed to put one back in. I've since seen Youtube videos where one hole is empty. Just 2 screws and one clip, instead of 2 of each. Makese me wonder if they aren't shipping with only one of those clips loaded.
I ordered an extra from China for $1, but I think I got a used one from the dealer before it arrived.
I have a bunch for my Acura and I didn't even check if they are the same size.
Mine seems to stay in place pretty well as long as the two screws are there.
It's good to have the panel but it could be easier to replace.
Thanks,
Wade
You can find several examples of after-market plastic push-pin fasteners and rivets for your need in this thread:
Aftermarket underbody rivets?
hi Wade, im new at this forum , but I might be able to help you,
there are 2 types of fasteners for that serice cover:
2 screws - oem code: 9CF60-0516B
and 2 clips - oem code: BGV4-56-145
regards
Sean
I believe there’s only one plastic push-pin fasteners (BGV4-56-145) used on oil filter access panel. And the description of these 2 parts is confusing.
9CF6-00-516B - Radiator Support Splash Shield Screw
BGV4-56-145 - Radiator Support Splash Shield Clip
Thanks everyone for the information. I found a combo pack on Amazon that has the correct size re the BGV4-56-145 fastener for the CX5 and some smaller fasteners I can use on my MX5 trim panels.
Wade
Since you asked here is the link to Amazon Canada https://www.amazon.ca/dp/B07X5RVNRZ/. If you are in the US you may have to do a search of Amazon.com.
Wade
Nah Amazon is a good guy vendor.. they simply change the domain and all the links stay the same
https://smile .amazon.com/dp/B07X5RVNRZ/
(l like using the SMILE for the donations
https://org. amazon.com/ ) ever since this forum went with automated affiliate links it clobbers smile links because only 1 type of link gets the credit -- either smile OR the affiliate not both)
https://www.amazon.in/dp/B07X5RVNRZ/
https://www.amazon.ae/dp/B07X5RVNRZ/
https://www.amazon.co.uk/dp/B07X5RVNRZ/
also
GOOACC 190 Pcs Car Retainer Clips & Fastener Remover
so you can find them on Ebay (of every region)
