YoungBuck23
- 2002 Mazda Protege5
Transmission won't change gears in "Drive", but changes gears fine in manual mode
Hey everyone, been trying to research what could be wrong and have found very little. I was having some engine and transmission issues in my 2002 Protege5, so I replaced them with the engine and transmission from a 2003 Protege5. The only difference was my 2002 had the automatic transmission with overdrive, and the 2003 had the automatic sport mode. I did swap over the shifter, cluster, and wiring harness. The car starts and drives fine, but the transmission won't change gears when it's in drive. It does change gears perfectly fine when it's in manual mode. It did not do this when it was in the 2003.
Am at a loss of what could be wrong, any help is greatly appreciated!
