Be aware that the part number for ATF pan FZC1-21-51XA on the Mazdaswag.com page is only for 2019 CX-5 2.5L NA with CD, which is different from your list. And there’re at least 2 different pans for 2018 ~ 2023 2.5L NA with CD. You need to do a visual check to the original pan, or may be use your VIN to find a correct pan from Mazda dealer. Read here:Is there anyway to identify what type of trans pan you have by vin#? 2019 CX-5 . I need to know if I have pan #................ FZ01-21-51XA, FZ01-21-51XB, FZ01-21-51X OR FZA1-21-51X.
Thanks
So how did you find out your 2019 CX-5 has “FZ01” or “FZA1” pan and you can use the gasket included in the kit from Blauparts.com?Yep. Thanks for the info. As a matter of fact I picked up that trans kit from Blauparts.
