Transmission noises
gixxerchaz
2008 Mazdaspeed 3
I took my car to a shop and they installed a ACT 6 puck spring hub clutch kit with flywheel. Now for some unknown reason I have what sounds like bad bearing noises coming from the tranny. When the car is in neutral and the clutch is engaged you can hear it slightly and when the cluctch peddle is in and disengaged everything is quiet. Also when driving in gear and you let off the gas you hear it also. I am wondering if they put the wrong oil in or WHAT?? Can someone help. Anyone had this issue?
Chaz
