Transferring Settings from older CX-5 to newer...Is there a way?
I'm replacing my 2021 CX5 with a new 2024 CX5. Is there a way to transfer all of my vehicle settings from my old vehicle to the new vehicle?
I would ask dealer if possible to transfer data but unfortunate they're all clueless. If you don't want to try the following procedure because of possible CMU incompatibility at least delete your personal information from your CX-5 2021.
From Workshop Manual:
Backup restore
1. Launch the diagnostic assist function. (See Activation Procedure.)
2. Select in the following order from the diagnostic assist function initial screen.
(1) [Service Information](2) [Backup Restore](3) [Backup]
3. Insert a USB memory drive into the vehicle.
Note
• Prepare a USB memory drive which has been formatted.
4. Set a password (8 to 16 digits in numerals only).
Note
• Record the set password which will be needed in the restoration procedure after replacing the connectivity master unit (CMU).
5. Back up the data to the USB flash drive following the instructions on the screen.
Note
The following information can be copied to the CMU after replacement.
• Radio settings (Programmed preset information)
• External device connection settings (CarPlay/AndroidAuto programmed information)
• Navigation settings (Location and home information registered to favorites)
• Center display settings (Contrast setting information, clock display setting information)
• System settings (Nickname information, touch pad function on/off setting)
• Audio settings (Equalizer setting information, listening position setting)
6. Replace the connectivity master unit (CMU). (Refer to the [CONNECTIVITY MASTER UNIT
(CMU) REMOVAL/INSTALLATION] in the workshop manual)
7. Launch the diagnostic assist function. (See Activation Procedure.)
8. Select in the following order from the diagnostic assist function initial screen.
(1) [Service Information](2) [Backup Restore](3) [Restore]
9. Enter the password (8 to 16 digits in numerals only) set during the backup procedure.
10. Restore the data on the USB memory drive to the CMU following the instructions on the screen.
11. Remove the USB memory drive from the vehicle.
12. Ends the diagnostic assist function. (See Ending Procedure.)
Personal Information Deletion
(1) [Service Information](2) [Personal Information Deletion]
3. Delete the personal information according to the instructions on the screen.
4. Ends the diagnostic assist function. (See Ending Procedure.)
