Just wondering if any one knows whether a manual trans from a 1.6 or 1600 2002 protege will fit our protege 5 have a automatic and working on changing it to a manual.
you guys may be better off trying to find a 2.0 donor car or in the junkyard or something.. not sure what all else would be involved? comparing the ATX models to the MTX models: is the ECU exactly the same? how about the throttle body? (coming from a dodge neon background, the automatics had a larger throttle body, which of course can be a great thing!) having another car available to guarantee you get all the parts would be a sweet thing
unless of course the AEM for the auto is simply "shorter" because it would hit the tranny? I don't know the difference between the two.. have you seen them both?
well this is a case where i must say, read TheMAN's FAQ, it for sure would have the part numbers for the two diffrent trannys.... so you could find out if it would work or not. probably not in my guesses.
eitherway, i woulda looked it up my self, but im lazy
