already did.. 3 times now twice at dealer and once on my own.. I do have a stock BPVTX Speed Demon said:noclue: sounds like you have a venting BOV rather than a BPV. Check for vacume leaks around your BPV if you're still running the stock one.
makako; most problems seem to be centered around the LSD. It's spot welded on and several forum members have had there's break. General opinion is the LSD takes most of the abuse from wheel hop and the three spot welds simply aren't strong enough to withstand it.
