Tranny noise, pulsating brakes, and bump on tire
What if I put rubber washers in between the heat shield and the frame? That might stop it right?
I've got the aluminum spacer between the heat shield and the car. Don't put the rubber spacer in it! It will melt!
Ohhhhh yeah, forgot that it gets pretty hot! DUUUHHH!!! I'm gonna try something later... to see if the sound goes away or not. How thick is your aluminum spacer?
I wish i had a dig. camera to show you the heat shield. Umm.. okay it is 2 separate pieces, one on top and bottom, covering the cat. converter. the edges of the shield are rolled, but rolled into each piece. I hope this is making sense... I actually got under the car to see what the hell it was, I hit it with a hammer at first around the edges to force both pieces back together, it worked for a bit but then rattled again. If you could get under the car safely and re-roll the edges together all the way around it may stock the rattling. Sorry if this doesn't make sense.
Top and bottom? Last time I checked, there was just one piece that went in between the converter and the bottom of car? I gotta go check later again to see...
Yeah there is two pieces, there in my garage now. But go check and let us know. Maybe the US model is different than the canadian model????
