fatti03msp
Contributor
- 03 MSP & 91 RX-7 & 00 1500
Hay whats up guys my buddy has a 98 626 with the 2.0 and auto tranny, and its starting to act up. Just wondering what route would be better to go.
whats going on.
from 1st to 2nd you have to play with the throttle a lil bit for it to shift but the car will shift into the 2nd. From 2nd to 3rd it shifts perfectly fine, but when the tranny tries to get into 4th it just wont do it.
The OD light blinks too, if you press the button the tranny will shift down/up but the light is always blinking.
After extended driving the fluid will actually burn up and start to come out of the breather tube thats connected to tranny pan. He has flushed the system and replaced the fluid and there where not metal shards int he fluid.
Could the filter be clogged and cause there to not be enough pressure in the tranny from the fluid to shift?
Or
Is a rebuild/new tranny the only solution?
Thanks in advance for the help.
whats going on.
Or
