Tramlining or worse?
maseraudi
Mazda CX9
Dear all,
It's been few months my 2009 CX9 (103K) has developed a wiggle when I turn right... But not always and that's the rub.
At first I thought it was the tires, so I hoped the wiggle will be gone when i put my set of 4 winter tires... It did not.
Brought the car to Mazda, took it for a spin, up on the lift: worn tie rod ends.
Change both tie rod ends: car is still wiggling only when I turn right but not always...
At this point, I would settle on tramlining because I would hate to look at a bad steering rack in the face.... unless the wisdom of this group tells me otherwise.
Thanks in advance for your help!
Fred
Balljoints & stabilizer bar links would be the next closest thing that have rubber parts, you might try replacing those.
