Traction bars?
Im sure this was probably posted somewhere but i couldnt find it so i figured id start a new one. Does anyone know about the medieval traction bars? If so do they cause any extra vibration? Also would it be a good idea to do a motor mount as well? Its for the MS3 GT by the way.
I have their rear motor mount, its pretty good, that said, I think it loses quite a bit of its stiffness over a few thousand miles. Pretty much and aftermarket motor mount is going to give you extra vibrations.
Can't say much about the traction bars, IMO, I don't think they do much at all.
Yea i was hoping for something that would keep its stiffness longer. Does it launch hard tho?
I have the Medieval traction bars and mounts. Traction bars work really well. Nearly no wheel hop. Only thing is sometimes when you turn there is a clunking noise. I was told that is normal since the heim joints are moving. The motor mounts are great. I had the TRZ and the vibes were to much for my GF, so we went with the Medieval mounts and almost can't tell the difference from stock in the vibrations.
Update!
ok everyone i got the Cp-e rear motor mount and it has worked out very well with almost no added vibs. My wife didnt even notice a difference. Thanks everyone for your help!
