TPMS Light Issues (2021 CX-5)
Hi Everyone,
No cash floating around? It ain't an issue at this horny fairground—in Free Chats you can still get a decent jerk without tipping a single damn penny! Just remember: being generous unlocks doorways to nastier playgrounds where these cam cuties pull out all stops.
Yes it's likely a TPMS sensor that is failing. Take it to a good tire shop and they can easily figure out which sensor is failing and replace it.
After you aired all the tires up to 34 psi did you press the TPMS reset button?
Do you still need to do that with the sensors? I know my 16 requires it but I've never did it in my 19.
No. The TPMS that has sensors in the wheels do not have to be reset in the same way that the ABS TPMS gets reset.
I've had a 2014, 2017, 2020, and 2023, and I've never seen that behavior.
In any case, if you need new ones, I used these in my new wheels, and the car must like them because I have never seen a tire pressure light with these wheels on.
Likely one of the sensor has a low battery (a button battery).
You can find a YT video on how to replace the button battery, but I won't recommend doing it unless you really want to take on the challenge..
