romandesign
- 2008 Mazda6
Towing 4000lb sailboat with CX9 - is it realistic and safe or is it hopeless?
We are looking for a 7-seat crossover that has good handling and cargo room, decent fuel economy and doesn't cost too much. I checked out everything that is available here in Canada. I like Mazda CX9 the most by far than other alternatives. There is one problem though: I hope to by a trailerable sailboat within the next 2 years: Macgregor 26X weighs around 3700 lbs to 4000 lbs with trailer and all equipment. All canadian CX9s are AWD, have "towing prep" package and are rated to tow 3500 lbs, which seems not enough.
However I have found out a curious fact: australian CX9 which seems to be completely identical is rated to tow 2000 kg (around 4400 lbs). People say that towing ratings on some vehicles are often low in US due to litigious environment.
If you look at the rough weights math it seems logical: according to weights I found on the internet (so please correct me if it's not correct) iit looks lke 8560 (GCVWR) - 4540 (empty Mazda) = 4020 (for loaded trailer and anything/anyone in the Mazda) which is close tp australian rating. Plus many vehicles have different rating for boats because of theirsuperior aerodinamic qualities relative to carvans for example. I need it for trips of up to 6 hours, Ontario is pretty much flat and weight of my family won't exceed 350 lbs for the life of this car. Add about 150 lbs for light gear and food for 2-3 days and we get to 4200 to 4500 which seems doable considering australian rating.
Anyway, even AWD with aftermarket hitch (like Hidden Hitch rated for 4000 lbs) Towing 3700-4000lbs seems to be uncertain. So I'm looking for advice and experienced opinions:
Is it possible and safe to tow 3700-4000lbs boat with AWD CX9 with 4000lbs-rated class III hitch?
Have you towed something as heavy on highways and what was your experience?
Due to exorbitant insurance rates in Ontario getting a cheap old truck just for towing sailboat is not an option. It will have to be one 7-seater SUV that does it all, or I won't be able to afford the sailboat. I'd like that SUV to be CX9 if at all possible.
Has anyone towed comparable weights with CX-9? Is it safe?
I'd appreciate all advice. Thanks.
