I had nokian hakkapeliitta 1's last year (set of 4).
Brand new when I got them.
I recommend another tire...
The Hakka's have a good tread pattern, and are very good if the snow is deep.
They are designed to be studded however, and we aren't allowed stud's in North America (except a few places).
The Hakka 1 has very thin sidewalls, which translates into wobbly cornering, unless you increase the tire pressure, which then gives you a worn patch down the middle of the tire...
The Hakka 1's are not a good tire when your on ice. They weren't designed to be an ice tire, because Nokian figured if you were going to be on ice, you'd have the studs in.
This year I bought a set of Blizzak WS-50's.
I bought them for their ice capabilities. And I have not been let down.
They also have a stronger sidewall, so I was happy with the increased cornering sensations as compared to the Hakka's.
Blizzak's shouldn't cost you much more, and I think you would be quite happy with the increased traction.
