Setting 35psi for winter tires to account for -20C temp would be ok?
Great! Thanks for your input!Absolutely. I do the same, 3psi higher than recommended, since I set my pressures in the underground garage which is 20-30 degrees warmer than outside in winter.
Correct me if I am wrong here.
Don't people set to lower PSI for winter driving? For better traction, I believe.
It's only better traction in snow and ice, not on cold, wet roads. Most of the time the roads are plowed and salted, in which case proper pressure is better.
