Tire/ Odometer Question
birdfeather
2007 Mazda 3 Sedan Black Mica
what size tire's do i need for these size wheels 17X7 5-114.3 50GBM for the odometer to read correctly???i have a 2007 black mica sedan 2.0 if that, also do you need to order tpms or can you use the ones from your old tire??
You can transfer the TPMS over from your old wheels if you don't plan on using your old wheels anymore.
If you want to use your old wheels for a second set as winter rims then you'll need 2 sets of TPMS.
You can use
205-50-R17
215-45-R17
225-45-R17
Stock Tire - 205/50R17
Section Width: 8.07 in 205 mm
Rim Diameter: 17 in 431.8 mm
Rim Width Range: 5.5 - 7.5 in
Overall Diameter: 25.07 in 636.77 mm
Sidewall Height: 4.03 in 102.36 mm
Radius: 12.53 in 318.26 mm
Circumference: 78.75 in 2000.2 mm
Revs per Mile: 829.6
Actual Speed: 60 mph 100 km/h
Speedometer Difference: -
Diameter Difference: -
Tire 1 - 215/45R17
Section Width: 8.46 in 215 mm
Rim Width Range: 7 - 8 in
Overall Diameter: 24.61 in 625.09 mm
Sidewall Height: 3.80 in 96.52 mm
Radius: 12.30 in 312.42 mm
Circumference: 77.31 in 1963.6 mm
Revs per Mile: 845.1
Speedometer1: 61.1 mph 101. km/h
Speedometer Difference: 1.868% too fast
Diameter Difference: 1.84%
Tire 2 - 225/45R17
Section Width: 8.85 in 225 mm
Rim Width Range: 7 - 8.5 in
Overall Diameter: 24.97 in 634.23 mm
Sidewall Height: 3.98 in 101.09 mm
Radius: 12.48 in 316.99 mm
Circumference: 78.44 in 1992.3 mm
Revs per Mile: 832.9
Speedometer1: 60.2 mph 100. km/h
Speedometer Difference: 0.397% too fast
Diameter Difference: 0.4%
haha thank you sir.. ya i was going do the research more thouroghly( is that how u ******* spell it haha?) but yesterday, i got a flat tire, and had to put my spare on, so now insteed of buying 1 new tire, im going to buy all new rims/tires like i have been wanting to do, plus my tread is getting to that point anyways lol...thank you much olestra :]
