R randyj69 Member : mp5 Dec 16, 2009 #1 if your timing jumps 1 tooth on the exaust cam will the motor still run
F flash75 Member : 2008 Mazda 3i 4 dr Touring Value Edition Dec 16, 2009 #2 It should run, but not very well. One tooth would a considerable change in cam timing. Clifton
P P-Funk! : Lancer Ralliart Sportback Dec 16, 2009 #3 Should you go back and make it right? YES. A pain to do? Yes. Now go do it! If you are troubleshooting a problem - give us more info.
