I am having a little trouble with my hood latch wire.
I pull on it and the hood does not pop open. I need someone by the hood to pull it up as I am pulling the wire. I am to assume with this that the wire is loose and that is what is causing it to only partially pop the hood. At least pop it enough for someone to pry it open with a little extra force.
My question is how do I adjust it for it to get the hood popping sound again? Is it related to the latch? Should I lube up the spring that gets pulled when the wire pulls?
Any help please. I am afraid my hood will just not pop one day when I need it to do so.
Thanks.
Thanks.
