Tighten P5 EBrake?
Partyman10195
2003 Protege5
When I pull my EBrake in my 03 P5 it doesnt lock the rear wheels at all, its a barely noticeable slow in speed which really does nothing to help me if I was ever in need to use it. Any info or how to's on tightening it in any way would be a great help. Thanks.
get a copy of the shop manual. it can be found in the protege section of the forums. in the brake section it shows you how to properly adjust the hand brake. you might want to check your brake pads first, to make sure they are not worn down too much.
first off, there is never any reason to pull the parking brake when you are moving. its why its called a parking brake and not an emergency brake anymore.
second. i would first check to see if your brake pads are worn, not much point in adjusting anything if the brakes are shot.
my guess would be the calipers are out of adjustment. easy to fix. there is a 14mm nut on the back of the caliper, undo that and there is an allen head bolt (4mm i believe) underneath it that adjusts the piston in an out. the 14mm bolt is essentially a protective cap. tighten the allen key all the way until it stops, then back it off at least a half turn. this will ensure that the piston is nice and close and when you pull the parking brake handle it engages quicker.
don't bother adjusting anything from inside the car. there is an automatic adjustment system that usually keeps the cables adjusted properly, but if your pads are worn way down, the way i just oulined for you should work pretty good.
I actually did adjust at the caliper during my last pad/fluid change and the parking brake lever has MORE slack in it than before. I tightened the allen nuts and backed off 1/4 turn (barely anything) in the process. Not sure where the nut/screw in the console is since I can't see it. Any ideas?
With the parking brake pulled up, put your hand in the rubber slit that covers parking brake lever and pull up. The plastic cover should come off with very little effort. Underneath you will clearly see the 10mm nut that you have to tighten.
if you have more slack after adjusting, you did it wrong.
i actually do not see this in the manual. can you show me where?
really?
check page 4-11-22 for rear caliper adjustment procedure.
also note, page 4-12-01 outlines the adjustment for the handle, and the only purpose to adjust at the handle is to make sure the light comes on. the brake adjustment is only done at the caliper.
really?
I was looking at the parking brake mechanism just the other day, it seems to me that the light will come on after the first click of the parking brake lever regardless of the tension on the brake cable. I'm pretty sure that nut on the parking brake mechanism is to compensate for slack in the brake lines when the pads have worn down (since our rear calipers don't auto-adjust).
I'll take another look today to make sure.
the rear calipers are self adjusting.
Oh, didn't know that.
Anyway, I took another look at the mechanism this morning and I can safely say that the nut that adjusts the tension has nothing to do with the parking brake light. The light will come on after the first click of the parking brake mechanism no matter what the tension is on the cable.
regardless, the proper way to adjust the rear brakes is at the caliper.
really?
thanks for the reply and apologies for thread jacking, but my problem is one caliper only, one side is engaging more than the other one. i will look at this bolt thinging.... this happened after a new re- man caliper installed.
but my problem is one caliper only, one side is engaging more than the other one. .
this is what mine keeps doing, but i think i have it set now. I jacked up the rear of the car, put on the E-brake and tried to spin each wheel. Adjusted from there
does anyone know if these car's require adjustment after the first adjustment?
Haven't checked if this is true in the P5 but most cars will auto adjust the rear brakes and parking brake when you stop after going in reverse. I would try to go in reverse at a resonable speed and then hit the brakes hard. If you do this a couple of times it should self adjust if it's stuck. If that doesn't work then you need to do what everyone has said before with adjusting at the brake calipers. Admittedly I have adjusted at the brake lever to tighten it further then I could at the caliper
New Threads
