throttle adustment
Moved... although there's really not a spot for engine tech in the normal P5 forum as far as I can see.
There is a problem causing the low idle, you don't need to adjust it you need to fix the problem. It could be a dirty MAF, vacuum leak, torn intake tube, dirty air filter, etc etc. First check for Check engine light codes and go from there.
