These roof rails?
Sure, but based on how they attach, by hooking on to edge of roof above doors, I wouldn't use them to carry anything substantial.
Note that capacity is spec'd for a dynamic load. Aerodynamics of the cargo you put on the rack could increase the dynamic load above the actual static weight of the cargo. So to be safe you would not want to max out the capacity of whatever rack you are using.
I'm learning about this. I asked the seller about a weight limit.
I thought if the basket were wide enough, I could strap it to the rails.
