The World's Baddest Pontiac Solstice with a V8
mikeyb
Contributor
01 BMW 325xi Touring
Who Wants Four When You Can Have Eight? That's the Logic Behind HOT ROD Stuffing an LS7 Into a Pontiac Solstice.
The engine swap is a tradition in hot rodding and HOT ROD magazine. Cadillac V-8s and Buick nailheads in Model A and B Fords were commonplace in the early days, and the musclecar was born via the concept of the engine swap. Anyone over the age of 35 remembers V-8 Vegas, Monzas, and Pintos, lightweight economy cars that were easily made to go very fast with a healthy small-block stuffed in place of the stock four. And let's not forget the V-8 Datsun 240/260/280Z, which combined Chevy V-8 power with the little sports car's inherent handling abilities.
Although the government and environmental activists make it increasingly difficult to wedge big engines into little cars that didn't come so equipped, we still can't help but look at most new cars and wonder how to stuff bigger or more powerful engines in them. When the Pontiac Solstice made its debut over a year ago, with an Ecotec four under the hood and a rear-wheel-drive platform, that was the first thought on the mind of each HOT ROD staffer. So, discussions began with General Motors Performance Division (GMPD) about how we could do it. What resulted was an agreement for GMPD to help us engineer the engine swap and sort out some of the more difficult details.
Over the next three issues you will see our efforts to build the car. In hindsight, the level of effort expended in order to create and refine this machine was perhaps over the top for the average backyard enthusiast, but the end product is, as the goal required, the World's Baddest Solstice. And the information we include in this three-part series will make it easier for anyone to do it at home, even if not on such a grand scale. As you will see in this story and the other installments, we used primarily GM production parts, and a lot of them bolted in with a minimum of fuss. Where they didn't is where things kinda got carried away, but as you'll see, you don't have to go as far as we did to have a fast V-8 Solstice.
What do we plan to do with this car when it's done? Everything and then some. Optimism says it'll be at as many of the HOT ROD events in 2006 as possible, including the Top Speed Shootout (Maxton, North Carolina, April 1-2), Pump Gas Drags(TM) (Memphis Motorsports Park, May 12), Power Tour(TM) (June 3-10), and Drag Week(TM) (September 11-15). If you go to one of these events, you can check out this car in person--assuming, of course, that we don't crash it. With the amount of labor, time, and money that went into this thing, that would be bad.
HOT ROD is showing how to put a V-8 in a Solstice for many reasons, one of them being that GM balanced the Solstice for the four-cylinder Ecotec engine family--nothing more. But that doesn't mean a more powerful Solstice can be only handbuilt. This fall, you'll be able to buy the Solstice GXP, a performance version that will have an impressive 2.0L, 260 hp, 260-lb-ft turbocharged Ecotec engine under the hood and a whole lot more.
While the 2.4L Ecotec that comes in the base Solstice is no slouch at 177 hp, the GXP version is just starting to show the real potential of this engine. The GXP Ecotec is the highest-specific- output engine ever produced by GM--making 2.1 hp per cubic inch of displacement--and the most powerful production Ecotec ever. It is also the first direct-fuel-injection engine offered by GM in North America. Direct injection means each fuel injector sprays the fuel directly into the combustion chamber, right at the piston. This technology is common in diesel engines and some European gasoline engines, but it is relatively new to the U.S. market. The turbo is a dual-scroll design that pumps air into an air-to-air intercooler stuffed in the front of the car for reduced inlet temperatures, making more power. The engine utilizes dual cam phasing to optimize the valve timing for maximum performance at low and high rpm.
The Solstice GXP will be easily recognizable on the street with unique front and rear fasciae and polished dual-exhaust tips. Other features you won't see but will no doubt be able to feel include GM's StabiliTrak four-channel electronic stability control and a 3.73:1 rear gear. Options will include a sport suspension, four-wheel disc brakes with ABS, a limited-slip differential (you'll want that in order to do good, smoky burnouts!), power windows/locks/mirrors and keyless entry (you can skip these to save weight), 18-inch polished wheels, a rear deck spoiler, sport metallic pedals, and an XM Satellite Radio, among others.
While the Solstice GXP is not yet available, early performance figures released by GM indicate the car will run 0-60 mph in 5.5 seconds and weigh approximately 2,950 pounds. It won't run with our V8 car, but that's pretty fast for a four-banger.
Top Three HOT ROD V-8 Solstice Performance Tips
1. Swap the Solstice rear differential for one out of the Cadillac CTS-V, which has stronger gears (the cases are identical). The power needs to go somewhere--make sure it gets to the tires!
2. Install a fire extinguisher somewhere in the car. With all that heat under the hood, you'll need something to cool you off.
3. Figure out a way to hang on! A V-8 in one of these rides is going to make it fly, so make sure you've got good driver safety equipment (racing seatbelts and seats, rollbar, and so on).
Roll Your Own
If you're thinking of building your own hot rod Solstice, you'll want to study this list. Many of the components can be ordered from your GM dealer via the listed GM part numbers, and some can be custom-built, such as the radiator. We'll list the custom pieces with their specifications and where HOT ROD got them. As a tip, if you don't want to spend the money for the dry-sumped LS7 crate engine, substitute a 400hp LS2 (PN 12499750) or LS6 (PN 17801268) crate engine in its place and use all the same engine dress components (they are common for the LS-engine family) listed below--it will still be plenty fast.
<CENTER>Hot Rod Solstice Parts List</CENTER>
DRIVETRAIN AND SUSPENSION (Description/Part Number)
Engine
LS7 V-8 small-block/ 17802397
Engine Components
LS7 GM Performance Parts Stage 3 cam/TBA
LS7 dry-sump components
oil tank /12603281
hose, engine to tank/ 15210122
bolt, hold-down for hose/ 11515758
hose, engine to tank / 15210117
Inlet components
Throttle body/ 12570790
MAF sensor / 12576410
CTS-V Engine Accessory Drive
Power-steering system
bracket / 12578551
bolt, pump to bracket / 11518075
pulley, ps pump / 12578552
bolt, bracket to head/ 11518633
hose, ps-fluid rsrvr to pump/ 25768914
hose, ps-fluid rsrvr to cooler/ 15145898
hose, ps pump to rack & pinion/ 89060184
(ends modified for Solstice r&p)
hose, ps cooler to rack & pinion/ 15145899
cooler for ps fluid / 25767911
Alternator system
bolt (qty. 2) / 11518637
bracket / 12578550
bolt / 11518630
alternator / 25750935
Belt/tensioner system
tensioner / 12569301
bolt / 11515768
belt, A/C compressor / 12585551
pulley, belt idler / 12568996
belt, fan/wp/alt/ps / 12578553
Air conditioning (not used here but common for all LS engines)
bracket / 12578548
compressor / 25752698
bolt, A/C compressor to bracket, long/ 11509202
bolt, A/C compressor to bracket, short /11518627
Starter
starter / 89017847
bolts (qty. 2) / 11588456
LS7/Z06 Components
Complete cooling-fan assembly / 10367894
Engine mounts
bracket, passenger / 10349964
bracket, driver / 10349965
nut, engine mount (qty. 4) / 11516079
bolt (qty. 6) / 11515767
shield for bushing (qty. 2) / 15254707
mount (qty. 2) / 15254700
Transmission
SSR T56 w/bellhousing / 15229017
(custom spacer used to clear long input shaft in trans & put shifter closer to stock location)
flywheel / 12571611
pressure plate / 24233650
bolts, pressure plate / 12561465
bolt, flywheel / 12553332
throwout-bearing assembly/ 15232236
transmission bolts/ 11518627
transmission yoke, SSR 32-spline / 26055083
Coolers
Four-core aluminum radiator, engine water-to-oil cooler, transmission oil-to-air cooler, and rearend oil-to-air cooler. Radiator supplied by Griffin Radiator
Suspension
Front: stock upper and lower A-arms, Ohlins adjustable coilover shock absorbers, and Hyperco springs
Rear: reworked mounting locations, A-arms and bracing to handle increased power, Ohlins adjustable coilover shock absorbers, and Hyperco springs
source:http://hotrod.com/projectbuild/hdrp_0605_pontiac_solstice_project_v8_engine_build/index.html
crazy!
in that first pic, notice how small buddie in the car looks.... or how big it makes the car look. The dood must be 4'2" :)
noclue119 said:
Sky > Solstice
I second that. I prefer the body styling of the Saturn over the Pontiac. Not sure I am ready to shell out 26K for a Saturn though.
i would its an opel. I mean u'd shell out 26k for a WRX or a TSX/Accord. WHy not an Opel. If its worth the car who cares what brand it is.
omg that is just nuts. I want updates on times and speeds from this monster. I want one.....maybe 2
I'm sure not by much. after all that all aluminum engine is pretty light. also the tranny is too and I'm sure they moved it back as far as possible.
is it considered a solstice anymore? my friend told me of a drag car that was an rx-7 with an ls1 engine swap...in my mind, that isnt an rx-7 anymore.
Dimitrios said:
No mention on how ****** the weight distibution got after this.
I'd say around 60-40 or better. Look at were it's sitting in the car. The front of the block is in the middle of the front tires and the transmition in in the middle of the car. It should have just enough weight in fornt to keep it down.
It's still a Solstice. The car it self it still all there. They just beefed up the drive train. Same thing as the MSP. Isnt this the same as if you change to a FMIC new turbo built block and trany?
That's a little different. The rotary mostly defines the RX for what it is: "Rotary eXperiment". The engine in the Soltice doesn't define it in a similar manner.
i wonder what tranny they used, because the tranny from a 'Vette is mounted at the rear of the car.
