Chris Barnett
- 08 speed3
I bought a speed 3 and now have about 1200 miles on it. When romping on it or shifting fast, it would grind into second and third every time. The feel was pretty vague, but decently weighted.
I ordered a set of TWM bushings, but they aren't here yet. I saw a couple posts about removing the counterweight, so I tried it. Shifts were much more direct, but the action was way too light. It felt skeletonized, so to speak.
So I compromised. I cut a little more than 1/3 of the counterweight. It is asymmetrical in shape, so I didn't cut the same width off of each side. I actually measured it with dial calipers, and cut it to match the same weight balance it had before. I cut 0.687" on one side, 1.2" on the thinner side. I also drilled two holes near the center for just a little less weight. Keeping it balanced might not matter much, but I figured it was best to keep the cables from being overstressed and snapping.
Major difference. It shifts with a more direct feel, and the throw is still nicely weighted. It's a lot closer to my old Mazdaspeed Miata now, except the throw is still longer, but proportionate for a wagon as compared to a roadster.
