Put the ones from the protege on the 3![]()
8.5" wide: +42 is nice and flush. +35 is as low as I would go without camber.
9" wide: +40 will clear most struts and be pretty flush. Any lower and you'll start to poke and need stretch/camber but you should be able to run around a +35 with rolled fronts.
old picture i found going thru some photos, kinda miss the white now
IMG_0359 by korbancorbett, on Flickr
