everything is stock, rotors, lines, pads, bleeder valve. Replacing everything to troubleshoot might be a good option, don't want to go through all that just yet though. Thanks for the offer, I'll keep it in mind.
I sent both an email, Keith already responded saying it's air in the lines and that I need to keep bleeding them, he's not sure about the power bleeder but it might be the ABS unit not letting the fluid go though.
I'm thinking about installing speed bleeders and keep trying: bleed, drive, trigger ABS, bleed, repeat. I'd rather not pay the stealership, maybe use that for new pads instead.
Replacing everything is one way to troubleshoot, but definitely not cheap. Are you planning on upgrading everything eventually? Your speed bleeder technique might be a good place to start though.
While we're on the topic of brakes...when I installed my coilovers, Evan #1 and I tried to install my Corksport SS brake lines. Well, we couldn't even get those damn fitting nuts off. They were stuck on there and I believe Evan even hit it with PB blaster. We ended up calling it quits so we didn't round the damn nuts. I'm not sure if it was just my eyes, but it actually looked like the flare wrench was messed up (could have been like that before). It looked as if it was stretched out, so the two sides were not perfectly parallel. Idk, I think I'll go buy a set of flare wrenches and try it again.
Does anyone have any suggestions or techniques? I think I remember reading someone used a butane torch to gently heat the area around the nut? Sounds like it could work, but I don't want to just do it and mess s*** up LOL! Thanks!
