ok, it's been almost 24 hours ... what's up????? i'm hoping everyone is A OK!!! including Nick ; ) lol
Ohhhh... I'm dumb. Haha. Btw, the tint on the 6 looks good, guy.
Little things need done this weekend...
-remove starter to clean (clutch dust builds up on it, causing a grind shortly after startup)
-while starter is out, replace reverse light switch (starter blocks it)
-mount my new USB panel mount cable
-194 LED's in the front park lights (may require bumper/headlight removal)
Good thing it's going to be super nice out!
Hey Josh, what kind of filter/water trap do you run on your home air setup? The compressor my buddy and I ended up getting doesn't have an outlet to drain it, so I'm betting the air is super wet and dirty, so I need some way to clean it before it screws up our tools. I'm planning on getting a plasma cutter as well, and I hear they're pretty picky with the cleanliness of the air. I'm sure you've got a sweet setup at work.
I'm thinking something like this would be pretty overkill, which might be enough, given the compressor situation.
http://akroncanton.craigslist.org/tls/2811699084.html
Happy B-Day Fabio!
