The engine whistles.....
the reason i ask, i installed my OBX header and now it whistles at high RPM under WOT
No i doesnt have a header, the engine is stock i guess... jejejeje i will going to check in the afternoon... thx for the info
could be a very fine crack or gap causing air release...think the blade of grass between your thumbs....My probe had a similar issue, found there was a very fine crack where the header met the cat
just keep an eye/ear on it...shouldnt be too much of an issue, it might also be a dirty air filter causing the whistle...just go snoopin around :) pop the hood, use the throttle control in the engine bay -which is on the backside of the engine (improper termonology i know) and try to figure out where the whistle is comin from
Defiantly sounds like a crack or leak somewhere.
I wouldn't drive too fast, or it may get bigger.
Rev the engine and have someone take a look and listen for where its coming from.
Oh it WILL get bigger if it is a crack, no matter what.
If it is a spun bearing - it will get much worse much quicker.
Mine was whistling when I accelerated. Hasn't done it in the past couple of days but I thought it was kind of weird. I have nothing installed though.
i check the engine and the noise came like in the back, in the muffler, any toughts?
++++ps sorry for the english :)
Is your muffler the original one on the car? If so, it's probably rotted from the inside out (happened to me). If you want to stay stock, get a QuietFlow muffler from Walker exhaust (lifetime guarantee). Otherwise, get yourself a nice catback :)
