sleeping_blue
- 2008 mazda speed 3
I was have a problem with under hard shifts or even some times just a high rev, between shifts i would have a have back fire an some times i was told i would have a fire ball come out the tail pipe. reading here on the forums i though, hmm go check the spark plugs. so i did i pulled out the first one and it split right down the side. right in my hands i pulled another plug it was cracked all the way around. the third plug from cyl#4 was not cracked but at the base off all the plugs the ceramic closest to the metal ( sorry dont know the ends outs of a spark plug) are all brown. jsut like the other two i pulled. here is the bad part,some of the ceramic fell right down onto the piston as i was pulling them out first off i dident know there were cracked second i was just clumbling apart like a suger cube. i fished as much of it as i could out with a screw driver wrapped with some ducket dape. an for the most part 4 hrs later i got most of it out. i ran to autozone got stock plugs put them back in the car started up fine. within the first 2 sec of it running i could here the remaning peaces bounce around an get shot out. i have double checked the gap on the ngk plus .028 was what there were set at. i guess im kinda lucky the motor is fine. an the turbo is fine it still spools up just normal. sorry for the poor qulity of the pictures they came off my cell phone. these plugs have 5000 miles on them. also with the new plugs in the back fire has come to a complete stop and the car idels, feels, an sounds alot smoother.
