flat_black
New info in post #3!
flat_black said:Well, no pictures this time, but a little bit of information that I forgot to post. =)
Firstly, I have some volumes for you all. Stock head specs are as follows:
Stock Head Gasket Thickness: .040" (1mm)
Deck Height: .060" (1.5mm)
Combustion Chamber Volume: 44cc (1cc max variance Low: 43.5, High: 44.5)
Piston Displacement Height: 4cc for stock 9.1:1, -4.7cc (Domed) for 10.4:1
I'll be ordering a new head gasket at .027" thickness, and the head is getting milled .010", which should bring me up to JUST shy of 11:1 compression, when all is said and done, and welding up the quench should put me around 40-41cc chamber volume, which puts me right where I want to be, at around 11.5:1 CR. =)
flat_black said:This was also cfrom ccing the chamber, lexan cover, burette, and so on. The headgasket thickness was from a stock, unused headgasket. Dished should be measured in positive volume (4cc), and domed should be negative (-4cc.) This does not include deck height, of course. I can try it again, but I'm pretty sure the results are pretty accurate, as the comes out comes out to aproximately right.
Doing it with your results of 0.026" gasket, .015" deck, and 9cc piston dish displacement, according to:
[(3.27 2)2 x 3.14 x 0.026 x 16.387064] + [(3.27 2)2 x 3.14 x 0.015 x 16.387064] + 36 = Vc (Compressed Volume)
[(3.27 2)2 x 3.14 x 3.62 x 16.387] + Vc = Vu (Uncompressed Volume)
Rc (Compression Ratio) = Vu / Vc
This ends up being 10.83:1 CR on the 10.4:1 pistons, and 9.35:1 CR on the stock 9.1:1 pistons.
I'm not sure exactly where the variances would occour in the measuring, but I can have DPR check the volumes and CR for me to make sure once I send them the stock head I have for flow testing, if you think they're way off. =)
flat_black said:Wow... Big font. The exhaust ports are 50mm wide, and intake are 52mm, that's a widening over over 3mm via porting, so it won't be accurate. For that matter, I've done extensive bowl work, and the valves are now swirl polished, the intake and exhaust ports are coated, as is the combustion chamber, so... It might be a bit off.
However, I do have a stock head (Three total, now), and I can get that flowed at some point. The issue with that is that unless you get the flow measured on the same machine, or same style machine, it won't be accurate. I intend to get the stock one flowed at some point, just to compare my results, but I don't think the flow numbers on this one will be too useful to you.
