I think to be really fair you would need to just change the filters and use the same oil. Changing the oil along with the filter means 2 changing variables and that Amsoil is among the best quality oil(drinks)
I agree, and you are absolutely correct. It's just that I started reading up on oil filters after I put that Mobil 1 filter in, and realized I was duped. Most of what I read pretty much said that OEM filters are as good as, if not better than some of the other store bought "higher quality/priced" filters.
At any rate, yes, the Amsoil did a little better than the Mobil 1 for me. Now I'm running the GC 0w-30 in the CX9 and my truck, and I when I get enough miles on the oils to take samples, I will compare the results of the GC to the Amsoil
I know a little off topic from the CX-9, but I just finished putting 8,300 miles on the Amsoil 5w-20 in my truck. On that fill, I changed the oil filter at 5k miles, and topped off with adding 1qt of oil. Blackstone said it looked good, and said to try 10,500 miles on the next oil. They said I wasted my time, and that I could have probably kept the filter in for the whole 8,300 miles. I drained the Amsoil and put in the GC on that oil change.
Blackstone Laboratories said:
Thanks for the note about changing the filter. Honestly, you probably would have done just fine
leaving the old one in use all 8,306 miles, but changing it out didn't hurt anything. It'll be interesting to see
how the Castrol does, but the Amsoil certainly got the job done. Wear metals are nice and low and compare
well with universal averages. A little extra silicon was present. Check the air filtration system just to be safe,
but it could also be a harmless sealer or additive. The TBN read 2.6 showing some active additive
remaining. Try 10,500 miles on the next oil.
Also, I sent in an oil sample from the CX-9 after putting 7,450 miles on the Amsoil SS 5w-20. There were 9,950 total miles on the car. I drained the factory fill at 2,500 miles and changed filters. Blackstone said to try 9,000 miles next time. When I drained the Amsoil, I filled it with the GC, and put a new OEM filter on.
Copper and silicon are quite high in this sample from your CX-9. It looks like this is only the
second oil change for it though, so we're looking at residual stuff from the wear-in process rather than a
problem. Copper shows wear-in at brass/bronze parts and silicon is from factory sealers and sand-casted
parts. Universal averages show typical wear levels for this type of engine after about 5,700 miles on the oil.
The TBN was 2.1 showing some active additive left; less than 1.0 is too low. Try 9,000 miles on the next oil.
Things should look considerably better.
It's amazing that I can run oil longer than the "recommended" intervals that the manual states, and still have oil that is in good condition, still doing its job, and have plenty of active additives remaining...LOL
