Yeah...dry startup that's great for it! Jiffy Lube has some engine flush that you'd dump in and run with the old oil before the change. Half a qt of ATF does the same thing.anarchistchiken said:Mobil1 is the s***. Excellent oil. My dumbass friend flush's his engine with diesel fuel whenever he changes his oil. Course he has a 76 diesel meredes, and I doubt theres a plastic gasket on the damn thing, but it still cant be good for it.
spacemonkey, do you have a CAI? Now this is just an assumption:spacemonkey said:10w30 for me all year round...is it good to change weight back and forth like that from 5w to 10w?
Also for the synthetic guys...are you hearing a scream...like a high pitch scretch once the turbo spools up. I heard its called the "Turbo Scream." Just wondering if its normal or is it just my car. Once I punch the throttle I'll hear my turbo spool up and around 3 or 4 psi hear the scream.
redfyre said:I use MObil1 synthetic all year round. You will not need a flush when you want to change from your regular oil to synthetic.
