gt28protege
- 2003 Mazdaspeed Protege
This is a question for people who have swapped blocks from Probes and 626s did you guys still run the stock oil cooler that comes on the Protege? Also, if you did how did you remove both of the threaded pins that hold the cooler and the oil filter on? I'm swapping to a 626 na block due to 2 spun rod bearings and cracked crank. Thanks in advance for all of the help.
