BillTheCat
- 2009 Mazdaspeed3 Sport
OK... here's the deal. I am interested in tightening up my suspension. (Bone stock '09 MS3 Sport) I'd like to reduce both body roll & understeer in tight corners. But I am not interested in lowering the car significantly, and don't want to trash the ride quality as a daily driver. (Coming from a MINI, the MS3 rides like a Caddy to me, so a little loss of smoothness is OK)
In the past, I have achieved this with springs & sway bars, so I feel comfortable that the same approach will probably do the job for the MS3. Sway bars, IMHO, are an absolute must, and I am liking the specs on the Hotchkiss set a whole lot.
I am wondering, however, if I should go with a set of coilovers instead of springs. It might be nice to be able to tweak & adjust the setup until I get it where it feels just right instead of buying a set of springs & being stuck with them. (I'm not one to buy the same parts over & over and keep replacing them)
But I'm not autocrossing or tracking the car, so it's not like I need to be able to adjust the suspension characteristics on a regular basis. So, having never actually installed & adjusted a coilover setup, I am wondering if it would just be overkill. Should I save some cash & just do the springs?
Part 2- Can this car take a mild suspension drop without needing aftermarket control arms, camber plates, etc. in order to keep camber in check? I don't see much mention of replacing those parts, so I am assuming that it's not much of an issue.
Part 3- Keeping in mind that I don't want to lower the car noticeably (I know that's blasphemy around here, but my personal choice), whichever setup you recommend, can anyone give firsthand recommendations on either springs or coilovers which improve handling without significantly slamming the car? (1/2" would be plenty for me, anything more than 1" would be criminal)
Many thans in advance for any answers, advice, and opinions offered.
