Suspension Question
Chris_Top_Her
Contributor
San Antonio, Texas
'15 CX-5 Miata AWD
I have lowering springs. Are coil overs a replacement for the dampers only, or an alternative to lowering springs? Or are they/can they be used together?
Coil overs are a replacement for lowering springs. They are better as they let you adjust the ride height.
http://www.aptuned.com/blog/coilovers-vs-springs-what-are-coilovers-and-whats-better.html
Generally "coilover kits" are replacements for both the spring and dampeners/shocks/struts. Largest reason as to why people upgrade to better performing coilovers is the option to adjust. For the typical track junkie, this is a convenience as it allows one to adjust the rebound, bound, dampening, height, and ultimately corner balancing. Though most entry and mid-range level coilovers allow only height and dampening.
