Hey everyone,
This is my first post on the forums, and I could use a little help with the precise parts to get to replace my suspension.
As of now, my '02 P5 has clunks in the front end, and the handling is crap compared to what it was a few years ago. On sharp corners, the front end bounces slightly to the outside of the turn. It can be pretty scary at high speeds (I'm pretty sure this is from chugging through sand.....long story). I have also noticed that the cabin noise level is much higher, but I'm pretty sure the wheel bearings are fine.
I have decided to go with the KYB GR-2s all around, but I don't want to lower the vehicle. Can I just throw stock springs on with them?
Also, what strut mounts would you recommend?
And do the stock endlinks work on the GR-2s?
Keep in mind that I am doing this on a budget! Plus, I also have to replace my rotors and pads, and perhaps even my rear calipers (pads are only rubbing on a portion of the rotor, the rest is rusty. Pretty sure they have had it).
I have a long drive planned 3 weeks from now, so any help would be greatly appreciated so I can get these parts ordered and installed ASAP!
