Subs and reciever questions
Dave2521
Black Mica Mazda 3
I just put some new polk component and some polk 6x8's speakers in my 3 over the weekend and noticed that I get a lot of sound but hardly any bass. So i started looking into some subs and picked out some nice 12" alpine type-E and a pretty good 500watt amp. However my question is do i have to get a new deck for my 3 for the subs/amp or can i run it without. And if i were to run it with out a new deck would it sound crappy?
I used my factory deck for my Infinity amp and 12 Infinity sub. It sounds great. My amp has about 300 rms. You will need a Line output converter though. So you can hook up your rca's to it because there is no hookups on the stock reciever. Also, I put my (LOC) Line output converter behind the deck. It was tight but I did it. Other then that it sounds great. The only reason i kept the stock head unit is because I think it looks good in there. And an aftermarket one would look stupid in the car i think. Check out my website of my car and my amp and sub. www.cardomain.com/id/lowridemazb2200
I was looking at yours last night. Went through cardomain to see how many people had a sub installed without an aftermarket deck.
Was the install of the amp hard? Thats the only problem i feel ill run into, I can install a deck and speakers just fine on my own, but never tried a amp yet! (doh)
thanks for the help
thanks for the help
First thanks for looking at my car on the website. Did you like the caer and all the sub and amp the way I installed That was my first time that I have ever done that before too. It was easy to me and should be to you. I'm one of those people that are a do-it-yourself kind of person. I like to learn how to do things on my own then I know more about things. It is easy. You can handle it. If you have anymore problems just let me know I will be gladly to help you
Yeah i like where you installed the amp at. Thats where im installing mine, its a good place to mount it i think. how long did the install take? Cause i only have today and tomorrow off work and i wont be getting the stuff by then :( so might have to use one of my PDO days. :)
Yeah It is a great place to mount the amp. Because I still need the trunk to put stuff in sometimes you kow what I mean. It took me about a day to do it. But, I did not work on it the whole day. So it was probably around 8 hrs of work. I finished at about 9:00 that day. Do you know how to run the power cable? Is your car a maual or an automatic. I have an automatic so to get the fire from the battery to the trunk you have to drill a hole in your car. There is a plastic piece on the firewall were I think the cluth would go. So I drilled a hole through that and pulled my wire through the firewall and into the car. IF you have anymore more questions just write me back, Thanks
