reoxxel how did you do the headlights in yellow?.... I like them just pm me some info. not bad on the front lip...It's different and that's what get it attention at shows good work.
removed the OEM mounting brackets from the underspoiler parts (as they were designed for mounting on a subaru). placed them with masking tape. marked the placement. Used a heatgun to mold them to the front bump mask (they're pretty close to the same curvature but not totally) filed the little pointy part a bit to match the sculpting, then slathered ATR 525 (I think that's what it's called, it's an aircraft adhesive) on the back. using the previous marking placed it and then screwed it in place (this stuff takes like 16 hours to setup but once it hardens it stronger just about anything else I've used) Once it completely cured, backed out the screws and used body filler to radius the joint and fill the screw holes. Then sand and paint.
wings west MSP said:
Nice man , I like it, did you get those from a wrx then fit them on , or what , I would like to know how it was done ,
